It is currently Mon Jun 30, 2025 9:32 pm
PostPosted: Mon Jun 05, 2006 4:54 am
Is there anyway that a dropdown or hyperlink can be made to make transfer from one section of the forum to another easier?
Just so I get this right, if I want to switch between the "Off topic Discussion" area and the "Main topic" area, I have to go back to the main page and "log in" again, than select the area I want to look at?
Is this the only way, or am I missing something?
PostPosted: Mon Jun 05, 2006 5:06 am
Rod just look at the bottom of this page. You can select your forum below.
PostPosted: Mon Jun 05, 2006 5:22 am
Doh!!!!!!! is there an emoticon for banging your head against a wall.
Thanks Bob, I feel small.
PostPosted: Mon Jun 05, 2006 11:27 am
[QUOTE=Rod True] Doh!!!!!!! is there an emoticon for banging your head against a wall.
Rod,
Will this work?
I need them sometimes too.
Patburbank38873.8536689815
PostPosted: Mon Jun 05, 2006 4:51 pm
PostPosted: Mon Jun 05, 2006 10:24 pm
Rod,if you use the (active topics view, then set your (Show Active Topics since ) to (last 16 hours or last day, you can usualy get any recent activity in ANY of the forums on a single page. The Main for will be first, followed by the OT forum, then the rest.
I use this to monitor them all.
It dont always work though, depending on how busy we are and how many (new threads) are started.
PostPosted: Mon Jun 05, 2006 11:40 pm
Cool thanks Lance that's a great way to navigate.
